Does anyone has digital signed a. .rtexe file which build from Labview?
When I built our application used Labview PXI got startup.rtexe file. Now we need to digital sign this file.
I first I tried sign .rtexe, it cannot sign, then our developer team suggested me to rename the file as Startuprt.exe. I tried again. I got below error.
SignTool Error: This file format cannot be signed because it is not recognized.
SignTool Error: An error occurred while attempting to sign: Startuprt.exe
SignTool Error: This file format cannot be verified because it is not
        recognized.
Message 1 of 9
(2,919 Views)
You have ended up posting in the LabWindows/CVI board! I suggest you repost this question to the LabVIEW board since it may be related to some item specific to the format of the executables created by LV.
Message 2 of 9
(2,877 Views)
What system do you try to run this real-time executable on? None of the NI Real-Time platforms will AFAIK require an executable to be signed in order to run it. And for other systems the rtexe file has about as much meaning as a Word Document to an Image Editor.
Rolf Kalbermatter  My Blog
Message 3 of 9
(2,865 Views)
Message 4 of 9
(2,845 Views)
Hi Jean,
is there a reason you need to create two threads for the very same question?
Message 5 of 9
(2,824 Views)
first time I created in wrong board. Someone suggested to move to this board.
Message 6 of 9
(2,811 Views)
one .rtexe run on windows and the other .rtexe run on Linux.
Message 7 of 9
(2,716 Views)
startup.rtexe need digital sign because development team think the .rtexe is same as .exe file and company security policy request all the .exe file need digital sign.
Message 8 of 9
(2,702 Views)
Hi Jean,
This is wrong, Windows does NOT execute RTEXE files…
Message 9 of 9
(2,688 Views)
