Does anyone have a VI for calculating orifice flow using AGA or ASME methonds
I'm taking data from an orifice flow meter including pressure, temperature, and orifice DP. Has anyone coded the AGA 3 or AGA 8 or ASME orifice flow calculations into a VI. I'm using LV 7.1. Thanks
(3,460 Views)
I see that 288 other interested parties have viewed this posting, but I do not see a response.  I have a short program in basic that we created some years ago that I was about to convert to LabView.  We created the program for both flange taps and pipe taps.  If you were successful in creating a LabView version, I would love to share it.  If not, I will continue working on my version and post it here later.
(3,171 Views)
I've written something in Mathscript... but tbh it is not well tested.  IIRC, we ended up just taking the data and then using a MathCAD worksheet I wrote a few years ago to convert to flow rate.
I was kind of hoping to see someone post a VI here as well.  Would Mathscript work for you?
(3,166 Views)
