Does anyone know how to add a folder with sample data to labview installer
I've put together a application installer for a project I'm working on.  I want to add a folder to the install with some sample data files.  Currently I've added a readme that tells the user to unzip a file included with the installer to a certain folder.  Is there a way to include this with the installer and automate the process?
(2,779 Views)
Accepted by topic author Jarad
First add any files that you want to include to the project. Then in the installer properties:
1. Use the destinations tab to add a folder if you want the sample files contained in their own folder.
2. On the source file page, expand "My Computer" and find the files in the project that you want to add.
3. Select the folder you want them to be located in on the right side and click the right arrow.
(2,772 Views)
I need to add an AVI file to my installer, so I  added this file to my project under "My Computer". Now when I do the step 2 above and expand "My Computer", this file does not show up there. Any ideas?
(2,749 Views)
Not sure. I just tried it with an AVI and it worked fine. It will show folders under My Computer, you may have to drill down to where the file is on your computer.
(2,732 Views)
I got it - the project with new file needed to be saved, and even restarted. It works now.
Thanks!
(2,718 Views)
