Does anyone know how to get data from a Labview web service with ajax or JSON?
Hi
There is no poblem to run this web services with a labview vi or directly with the browser. The problem is the parserror I get when I use jquery(javascript).
Attached is a zip file with the project and the html files
Thanks...Eran
Message 11 of 16
(1,534 Views)
Ahhh... so its specifically a jquery problem.
I did that once, but don't have the code with me. I'll look for it tonight. In the mean time do some checking with the jquery support forums.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 16
(1,532 Views)
Message 13 of 16
(1,520 Views)
Hi there, i think i've got exactly the same problem.
i've a vi running as webservice which should output just plain json, which is ok when i run it via browser.
when i use it in jquery - nothing happens, the response is empty although other non-labview json sources are working.
i can only guess what this really is but maybe someone has a clue, this really gives me headache!
thanks a lot
andy
Message 14 of 16
(1,457 Views)
Accepted by topic author Eran1965
I found the cause for the problems
You can not add header("Access-Control-Allow-Origin: *") when you build the webservice (in the servere side)
You can get json with labview but you can not get JSON (from labview webservice) with javascript code
Message 15 of 16
(1,432 Views)
it is def. the sop problem and after putting the whole stuff onto the NI webserver it worked. i'm currently trying to get jsonp to work - i found some NI document were they refer to jsonp and therefore i hope this will work out!
Message 16 of 16
(1,426 Views)
