Does anyone know how to locate where a standard labview vi is in a library?
I have vi's I built that access standard labview vi's. I can't seem to find the SQL vi's (SQL Execute.vi,...etc). It says that they are supposed to be in \program files\national...\labview 6\user lib\xx but are not there? Any help would be appreciated.
(2,842 Views)
When I installed the toolkit for 6.0 and 6.1, it got put into \vi.lib\addons. Under that, you should have a SQL folder with Access, Intrface, and Menu folders under that. That was with version 3 of the toolkit. If you don't have the files anywhere, you should try reinstalling the toolkit. They are not part of the normal LabVIEW distribution so if you recently upgraded or did a reinstall of LabVIEW, you wil have to install the toolkit separately.
(2,842 Views)
Hi Dennis:
I have a similar problem.  where is the toolkit that needs to be reinstall.  I did a browse through my LabVIEW CD, but i didn't see it.
please assit.
(2,683 Views)
