Does anyone know how to pass a character array into Fortran from Labview?
Can everyone tell me how to write the fortran code?
Thanks!
Message 11 of 15
(911 Views)
I'm sure a Fortran forum is a much better place to ask this. The obvious question there would be how to pass string data from a different environment (C program or Visual Basic for instance) to a Fortran DLL. They can for sure tell you that, here we do LabVIEW. Fortran I only know by name and that it is something I'm never going to learn.
Rolf Kalbermatter  My Blog
Message 12 of 15
(907 Views)
  I'm not a Fortran programmer, so I'm sure this is a pretty ugly way to do it, but it did work:
  I did something like this:
subroutine MySubroutine(FileName_RT_Byte, FLen)
BYTE :: FileName_RT_Byte(100)
BYTE :: FileName_RT_Byte2(100)
CHARACTER(LEN=100) :: FileName_RT_Char
INTEGER :: FLen
EQUIVALENCE(FileName_RT_Byte2,FileName_RT_Char) !Make the character filename equivalent to incoming filename byte array
FileName_RT_Byte2(:) = FileName_RT_Byte(:)
!Test code (un-comment to use)
!open(unit = 11, file="TEST.txt")
!WRITE(11,*) 'TEST12345'
!WRITE(11,*) 'aa '//FileName_RT_Char(1:FLen)//'|2'
!WRITE(11,*) FLen
!close(11)
!Assign PriFile based on passed in string
PriFile = FileName_RT_Char(1:FLen)
!Remainder of the code deleted
end subroutine MySubroutine
Hope this helps!
Message 13 of 15
(887 Views)
Ergh, the smilies were inserted by the forum, replace them with a colon then close parenthesis
Message 14 of 15
(886 Views)
Thank you very much!
I have got it a few days ago, and not need  the length of the filename or EQUIVALENCE command.
Best regards
Message 15 of 15
(873 Views)
