Does anyone know how to the invoke node "Reinit to Default"? (see attached VI)
Thanks a lot Berth for the explanation. If I want the listbox to show nothing, I will write nothing  "  ".
Message 11 of 23
(1,442 Views)
Bingo! No need to use the Invoke node.
Message 12 of 23
(1,440 Views)
No, it's only 10% of the BINGO. LOL .  So I am able to reinitialize only the first column of the table every 10 seconds (see this updated attached code).Now how do I go about reinitializing the whole table every 10 seconds? This is the problem I having now. I am also working on it. I attached my updated code.
Another problem I am having is when I reinitialize, I would like to restart loading data from the very top (3rd row). If you run  the code, you'll see what I am talking about.
Have you ever done what I am trying to achieve?
Message 13 of 23
(1,434 Views)
Accepted by topic author GRCK5000
How about trying this?
Former Certified LabVIEW Developer (CLD)
Message 14 of 23
(1,425 Views)
And The Trophy (Best answer) goooooeeees to Frozennnnnnnnnnnnnnnnnnnnnn!!!!
Thanks a lot!. Problem solved.
Message 15 of 23
(1,413 Views)
You still have glaring errors.
  • You cannot use [i] because that even increments in the reinit case, thus messing with your count.
  • If you compare the reminder with zero, you'll also init at the first iterations
  • If you cycle through all state, a simple +1 will correctly wrap once the state enum runs out of items.
  • You are not really doing anything based on time, but on line count.
Here's a quick draft that seems to work more correctly.
Message 16 of 23
(1,404 Views)
And if there are really only two states that switch at regular intervals, you don't even need an enum.
Message 17 of 23
(1,401 Views)
Thank you very much Mr. Altenbach. This is great! I learned to stay away from feedback node. I'll stick with shift registers from now on thanks to you.
Message 18 of 23
(1,382 Views)
Best advice always. Thanks Mr. Altenbach!
Message 19 of 23
(1,379 Views)
I'm sure that's not the intended take-away lesson.  altenbach frequently advocates FOR feedback nodes as a more compact alternative to shift registers.   There are specific use cases that favor each method over the other, but also a lot (probably more) where either method can be used effectively.
-Kevin P
Message 20 of 23
(1,367 Views)
