Does anyone know how to use Labview or teststand to communicate with MPLAB ICD3 to call a file to program a PIC18f4580 microchip?
Hi, I have a DUT which is manually tested with many different types of debuggers and SW applications. I have been given the job of automating this using teststand and labview. I can automate a lot of it quite easily but i have hit a hurdle. The manual measurement currently uses MPLAB SW with an MPLAB ICD3 to program the PIC. It does this by simply calling a file and telling the SW to program. This is then verified by a verify complete message in the SW. I am pretty sure the MPLAB ICD3 kit is connected to the host PC using RS232.
Is there a relatively simple way of communicating with this ICD3 device/MPLAB SW to get it to do the above?
Any suggestions or pointers welcome but the more detail the better. Cheers
(2,737 Views)
miggins,
Does the ICD3 include command line control?  Have used this method with older Microchip programmers.  LV code just pops open the command prompt and executes a line of code.
(2,723 Views)
