Does anyone know of good resources on using Labview with Omega DAQ (3000 series)?
I'm fairly familiar with the labview environment and have used NI DAQ devices with ease as it's all set up through the help assistant in Labview. I am now utilizing an Omega DAQ system and have some troubles with understanding the VIs supplied with the system. Any resources on this would be greatly appreciated. Thanks
(2,318 Views)
Darshwings,
Unfortunately we do not have support for 3rd party drivers and I was unable to find any resources on our end for learning how to program with Omega's functions. Typically, instrument drivers come with some examples when installed. I would check the location of these drivers and see if there are any examples. Otherwise you may want to contact Omega for any documentation that is available.
Huntington W
***Don't forget to give Kudos and Accepted as Solution where it is deserved***
(2,295 Views)
