Does anyone out there have any information about running LabVIEW 6i on a Windows 2000 Dell Inspiron 7500 laptop?
Good news, bad news. I will take any info I can get. I am having trouble getting LabVIEW to see an HP 8703 device. I used to have Win98 and LabVIEW 5.1 running on this machine without a problem until I tried to upgrade to 6i. The machine would not work correctly or recognize devices consistently.
Thanks for your help!
(2,623 Views)
The problem you are seeing likely does not have to do with LabVIEW, but more likely with the GPIB drivers. If you did a full install of LabVIEW 6, it probably installed new drivers over the old ones and might have caused some problem. You aught to be able to test the 488.2 drivers and the device communication using MAX (Measurement and Automation Explorer) If have trouble communicating with your device in MAX, might want to consider completely uninstalling the drivers and reinstalling.
(2,623 Views)
