Does exe builder ignore language settings?
In the Run-Time Languages tab of my Exe properties I only have English checked for the supported language. Yet when I build the installer for the exe the setup.ini file contains all kinds of references to other languages and the files created also contain other language references. Why are all these other languages included? The installer size is bloated enough without having all these extra language references.
I'm using LV 2009 SP1, but this has been going on for many revs.
George
(2,460 Views)
Hi George,
I do also see this performance, when trying to select just English as the supported language.  I believe that this "supported languages" option is referring to when the executable is running, not necessarily to all of the licensing files that are associated with the executable.  I'd recommend creating a product suggestion for this to trim down the size of these installer files.
Cheers,
Marti C
Applications Engineer
NI Medical
(2,429 Views)
