Does exist a run-time engine LV 8.0 for NT ?
I have developped a program in LabView 8. I need to run it on an older machine (PIII 550 Mhz), actually running under Windows NT 4.0 SP6. It seems that the run-time engine of LabView 8.0 is no more compatible with NT. Is it true?
Well, I can upgrade the OS on this older machine, but... 😞
Thanks.
Jiri
(2,608 Views)
Hello Jiri,
afaik LV8 requires WinXP as minimum. So you better use LV7 (or even LV6) for your older WinNT/P3-550 machine...
(2,603 Views)
Hi Jiri,
LabVIEW 8.0 works on both Windows 2000 and Windows XP.  LabVIEW 7.1 was the last version of LabVIEW that will support Windows NT.
-D
(2,589 Views)
