Does labVIEW evaluation software have relay swtiches?
hey. my question is very simple. basically i'm trying to model a control system using labview evaluation software that i downloaded onto my laptop (windows xp). i know there is a simple SPST switch that is included, but i need a SPDT and DPDT (although the latter is not as important). am i just missing their location in labview? or is there anywhere to obtain these items?
(3,290 Views)
LaVIEW really doesn't have any relay switches which are hardware, not software.  I know there is an Express VI called relay, but that is kind of a dumb VI.  It basically just uses a lot of code to wrap up some pretty simple operations.
Anything you want to do with "switches" in software can be done with booleans and case structures.
(3,287 Views)
What is the control system you are trying to model?
Here is a link to some the eval version of some products (Control Design and Simulation, System Identification, PID control and more)
https://lumen.ni.com/nicif/us/evaltlktcds/content.xhtml
Also, you can build your own control based on xcontrols. Use the SPST to create your won SPDT and DPDT and post it online!
http://zone.ni.com/reference/en-XX/help/371361E-01/lvconcepts/using_labview_xcontrols/
Cheers!
Javi
(3,282 Views)
well i can make my own the concepts behind relay switches aren't difficult. but basically i'm trying to simulate an AC power source, so i'm using a simple sine wave as my input (i have two), and then basically putting these two sine waves through a few relays so that one will finally end up at the end. i know switches are just boolean logic, and that's not hard, but you can't take a sine save and put it through logic gates. that's where i'm having trouble. advice?
(3,276 Views)
It could be something as simple as the options below:
Start by learning LabVIEW and programming basics. One place to start is here.
(3,270 Views)
You can model the two relays with the examples Dennis provided.  You can wire any similar type to the selector to better represent your model.
(3,229 Views)
