Does polymorphic vi's adapt in execution time?
I'm new in LabView and I would like to know if polymorphic VI's adapt dinamically to the datatype in execution time.
Thanks in advance.
(2,657 Views)
Accepted by topic author marccj
No, determination which instance has to be used is done in edit time before compilation.
You can either select the instance manually (selection by drop down list, necessary for polymorphism for outputs) or (for inputs), it adopts automatically.
Norbert
Norbert
Expert: Geometry
(2,652 Views)
It adapts at edit time.The correct instance of the VI will be chosen when you wire the inputs, from then on there is no change/adaption unless you go ahead and change the type of input.
(2,647 Views)
Ok, thanks both of you for your responses!
Best regards.
(2,644 Views)
