Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Does " IMAQ Match Pattern 2 " support 16-bit images?
dazee
Member
01-07-2006
01:11 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi,all
When I used " IMAQ Match Pattern 2 " to process 16-bit images, it didn't work. I tried the " Pattern Matching example" and have changed the IMAQ Create's "image type" to 16bits.
Is there any method to solve this problem?
Many thanks!
0
Kudos
Message
1
of 2
(2,483 Views)
Reply
Re: Does " IMAQ Match Pattern 2 " support 16-bit images?
Christian Mergl
Trusted Enthusiast
01-10-2006
11:25 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hello dazee!
"IMAQ Find Pattern 2" only supports 8bit images! You can find this in the help.
Kind Regards, Christian
0
Kudos
Message
2
of 2
(2,471 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
