Does sombody have a labview driver for the Scanlab rtc2 scanner controller
Not to bring a thread back from the dead twice, but would you be willing to share your RTC4 VIs? I could sit down myself and figure it out over a week or so, but I thought I'd check to see if I didn't have to reinvent the wheel.
Thanks.
Message 11 of 14
(1,827 Views)
Hi, I based mine on this examples, I am, not sure they work, but it shows you what to do. Just make sure you point to the right DLL that comes with your board.In my case everything points to RTC4DLL.dll
Get the programing reference manual for your card if it s different.
regards
Lukasz
Message 12 of 14
(1,808 Views)
Hi Lukasz,
Do you happen to have VI's that combine the ones in this attachment? Like a master VI that controls the RTC card?
Asheesh
Message 13 of 14
(1,214 Views)
Does anyone have an example of labview code for Scanlab RTC4?  I have generated a vi library from the source code for RTC4 but is having problem communicating with the board.
Thanks much!
Message 14 of 14
(1,042 Views)
