Does the NI-VISA driver wizard create drivers that are compatible with the 64 bit version of Windows XP/Vista?
Does the NI-VISA driver wizard create drivers that are compatible with the 64 bit versions of Windows XP/Vista?
CLED (2016)
(4,108 Views)
Accepted by topic author InfiniteNothing
InfiniteNothing--
If you are using a 64-bit compatible version of the NI-VISA driver, then the NI-VISA Driver Wizard should create 64-bit compatible device drivers that run in 32-bit mode.  You can find the different NI-VISA drivers at http://joule.ni.com/nidu/cds/fn/p/sn/n23:1640/lang/en.
Take care!
Tyler C
(4,065 Views)
Thanks. To clarify, you're saying it doesn't matter what version of the Wizard I used to create the INI? I just have to tell anyone using the INI I generated to run the latest version of VISA?
I assume that VISA 4.4 has Vista x64 compatibility it also has XP x64 compatibility? Only Vista is listed on the link you provided.
CLED (2016)
(4,045 Views)
The discussion forum that Dennis linked explains it exactly as it does depend on the version of driver.
Cheers!
Tyler C
(4,012 Views)
