Does the Report Generation Toolkit serial work with older versions?
My office has the 2012 version of LabVIEW which uses the 2012 version the Report Generation Toolkit. If we buy the RGT on the NI website will the serial key work with the 2012 version? I don't see any option to purchase older versions of the RGT.
(3,270 Views)
you have to use property node for this one
(3,257 Views)
Is this reply intended for this message thread?  Because it doesn't make sense with respect to the question.
(3,245 Views)
As I know most of report generation are based on activex and property node
so for lower version it could be helpfull to work with them
I have to complete my answer with indicating active x too
sorry for incomplete answer
(3,241 Views)
The answer is "Probably not".  It is not so much that the License is "wrong" (I assume that is what you meant by "serial number"), but if any of the VIs and functions in the 2015 RGT have been compiled for LabVIEW 2015 (or 2014, or 2013), you will not be able to open them with LabVIEW 2012.
I recommend you get in contact with your NI Sales Team and discuss this with them.  An alternative "solution" is to purchase the LabVIEW 2014 or 2015 Professional Development System, which includes the RGT.
Bob Schor
(3,227 Views)
