Does the VLM get confused with multiple IPs?
My laptop can have one IP when I'm connected to the wired LAN in my office, several different IPs when I'm at and about within my company's wireless network, and yet several different IPs when I login over the VPN.
Does the Volume License Manager get confused by registering the machine I checked a LabVIEW license from, then lose connection and/or reconnect under another IP, close LabVIEW, and doesn't release the license?
Right now I can see that I still have one license checked out under my laptop's name, even though LabVIEW no longer is running.
Starting LabVIEW on the laptop and exiting does not release the license.  Starting LabVIEW and looking at the in use licenses, still shows a network checkout from an earlier time.
This doesn't seem right to me.
(2,341 Views)
Could you please repost your issue on the VLM Board: http://forums.ni.com/t5/Volume-License-Manager-and/bd-p/410
Also, when you repost, please provide the following information:
What type of VLM are you using? Is it concurrent or non-concurrent? Is it named-user, computer-based, or unmanaged?
-Mike
(2,277 Views)
