Does the code generated by LabVIEW C Generator depend on LabVIEW RTE(Run-time Engine)?
I've written some VIs using LabVIEW Primitive VIs. And I'd like to build them to dll for protection. But the Dll built by LabVIEW will depend on LabVIEW run-time engines. So I am wondering if there is a way to work around (No dependency on LabVIEW RTE):
1. generate C code
2. Build dll from C code.
Is it doable?
Thanks!
Message 1 of 1
(2,757 Views)
