Does the inport/outport VI inLabVIEW 7.1 used to communicate with EPP
I have to create an interface to communicate with a device using the Parallel Port in the Enhanced mode (EPP).I have wriiten a few programs for reading/writnig to the Standard Parallel Port(SPP)and they work properly.I want to know whether the Inport/Outport VIs in LabVIEW 7.1 capable of handling the EPP protocol.When I try to use the same programs in EPP mode (address hex 378 + 4), the programs don't seem to work.I am attaching a sample program that I am using.Somebody please help me out.
(2,547 Views)
Hi Sudeep,
The following discussion forum posts address similar questions. You may want to have a look at these if you haven’t already. Hope this helps!
Best Regards,
Chris J
LabVIEW EPP control using Windows 2000
http://forums.ni.com/ni/board/message?board.id=170&message.id=27641&requireLogin=False
Help building drivers for custom-built hardware over EPP (Enhanced Parallel Port) on NT
http://forums.ni.com/ni/board/message?board.id=170&message.id=4683&requireLogin=False
How to read 32 bit from my EPP 32bit data register?
http://forums.ni.com/ni/board/message?board.id=70&message.id=1665&requireLogin=False
(2,536 Views)
