Does the real "PXIe-4300"-instrument record permanently? How can I record a single wave?
I need to use the "PXIe-4300". As I have not installed the real device at the test bench now, I use the simulated instrument with the help of Measurement & Automation Explorer and LabVIEW. The instruments and my VIs accessing the PXIe-4300 are running well.
In the MAX I can select that only one definite wave is recorded. That is excactly what I need.
Is it possible to configure the real instrument in a way that it only records one wave as well? How can I do it? Or do I have to implement a separate VI to set the measurements of PXIe-4300?
Thank you for your help.
(2,396 Views)
The whole point of simulation is that you can configure the simulated device in the exact same manner as with an actual device. So, you do not have to change a thing in your code. You will only need to name the actual device the same as the simulated device.
(2,389 Views)
