Does the string will overflow?
I want to use a string indicator to show continuous test output (continuously concatenate the new output to the end of current string). This test may run about several days. I want to know if the string indicator's length limit, is it possible that some error happen like overflow?
(2,867 Views)
Accepted by topic author wellsc
It will go until you run out of memory. I would suggestion having some sort of limit. If the string gets to length "x" delete the oldest line.
(2,866 Views)
Thanks for your idea.
(2,860 Views)
