Does the voltage to temperature conversation require in usb 6008 using daqmx 8.5??
Another question need u all guy help.I currently using K-type thermocoupler for my project using usb 6008.Does the voltage to temperature conversation require in usb 6008 using daqmx 8.5? what is DAQ TEDS function use ? is it help us to convert?
(2,680 Views)
You will need to factor the voltage per degrees C to get to reading in degrees, this is 10mv per degree V for the device mentioned in the post you previously made
https://forums.ni.com/t5/LabVIEW/what-amplifier-will-recomended-for-my-k-type-theromocoupler/m-p/518...
TEDS - Transducer Electronic Data Sheet
A video about TEDS
http://digital.ni.com/demo.nsf/websearch/8e55de8fe6b5702686256e7c007a47b4?opendocument
(2,673 Views)
