Does this graph exist in Labview?
Hello to all.
I would like to use this graph in Labview but I don't know it it is exist:
Where I would give "line" and (x,y) coordinates.
Thanks a lot.
(5,013 Views)
Check : Common Plots—Provides options for the plot type. You can select a line, scatter, line and symbol, fill, comb, or bar plot type.
Ref: https://www.ni.com/docs/en-US/bundle/labview/page/customizing-an-analog-plot-using-the-plot-legend.h...
-Use Common plot as line and Point Style to dots
uday
(5,004 Views)
you can build something like this with a Waveform Graph
(5,003 Views)
Thanks a lot for replying.
Where can I find the example you post in .png to open with labview?
Thanks a lot
(4,991 Views)
Accepted by topic author A.Salcedo
I build it myself, you may use this snippet
(4,971 Views)
Thanks a lot.
I have another question:
I would like to do the next.
When X coordinate is 100, then I would like to remove first point and introduce the new point in x=101.
Do you understand?
Thanks again.
(4,932 Views)
So you want a Chart with a buffer set to 100 ?
Change the Waveform Graph to Waveform Chart.
Or maybe a ringbuffer?
http://search.ni.com/nisearch/app/main/p/bot/no/ap/global/lang/da/pg/1/q/ring%20buffer/
(4,921 Views)
