Doing continuos integration using Labview
I am using Labview 4.1, but I think this
is irrelevant.
I am using the Integral VI in the
Digital Signal Processing to do
the integration. In the test program
I am trying to perform
continuos integration of some
signal.
The signal generator uses sample sizes of 128 and the integration
reset the integrated value to 0
every 128 samples.
What I want is to have the integration
accumulate the integrated value
across interation of the loop.
How should I do that ? Labview does not
allow the output of the integrator to be fed
back to an adder which connect to its input.
(2,850 Views)
Have you tried using shift registers? That way you can wire the output to the input, just right click on the while loop edge and select add shift register, the value in the right will be passed to the left for the next iteration.
Hope this helps
(2,850 Views)
