Dos NI provide labview drivers of agilent/keysight b1505 instrument?
I have to automate a probestation which uses the b1505 power device analyzer. I could not find any labview drivers for the same.
(3,535 Views)
Is the instrument similar to the 1500?  http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=7864
Generally, the drivers NI hosts are found at www.ni.com/idnet  From there, you can see if agilent has made them available or if you'll need to talk to agilent directly to get the driver.  Potentially, you may need to build your own.
(3,532 Views)
It doesn't look like NI does. Keysight links to a different software platform to control it called EasyEXPERT.
Maybe you could try the NI driver for the 1500A.
Cheers
(3,526 Views)
