Dose desktop PC in RT supported all series(for example e-series) I/O cards?
I want to use desktop pc in labview real time module for target.
Does it support all i/o card or boards of ni?For example dose it support cards that simulink and xPC Target support in RT application?Does it support E-series and M-series of Ni boards?
I need your help.Does anyone uses E or M series board of NI in desktop PC target?
Thank you for your help.
(3,312 Views)
It's not the RT Desktop PC itself who must support the target, well at least it should provied a free PCI or PCIe or whatever slot you need.
The DAQmx driver is the one who supports the hardware products you mentioned, and this driver will also run an a Desktop PC which fullfills the requirements for a LabVIEW Realtime Target.
Christian
(3,268 Views)
Thank you.
Is it possible that i use SIT 5 with 2 e-seris daq card(PCI6023 - PCI6034) in Real-Time Project?I use desktop PC  for Target.
I have error when i do this configuration.Does SIT 5 support desktop PC for target?if it possible,how i can create custom driver for my project for use multiple daq device?Dose anyone has custom driver example of SIT for multi-daq device that contain IO base rate loop(IO init,IO read,IO write,IO close)?
(3,051 Views)
