Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Dots on Block Diagrams
Garry Lops
Member
04-24-2003
08:59 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Does anyone know how to get dots on wire junctions?
0
Kudos
Message
1
of 4
(2,785 Views)
Reply
Re: Dots on Block Diagrams
LucaP.
Active Participant
04-24-2003
09:12 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi Garry
In LV 6.1:
1.Goto Tools>>Options
2. Select "Block Diagram"
3. Enable the "show dots at wire junctions" option
Luca
Luca
1
Kudo
Message
2
of 4
(2,785 Views)
Reply
dhuff
Member
04-24-2003
09:17 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Under the Tools menu, click on Options, then use the drop down menu to go to Block Diagram. Check the option "Show Dots at Wire Junction" if you want dots to appear. After you click OK, you want to restart Labview to have it take effect.
dhuff
1
Kudo
Message
3
of 4
(2,785 Views)
Reply
Davy
Member
04-25-2003
01:55 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Go to Tools -> Options -> Block Diagram and select show dots on wire junctions
1
Kudo
Message
4
of 4
(2,785 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
