Double Accelerometer Measurement
Hi Cla,
When I read around, it says that the dynamic data is limited to VI express output.
So I tried merging the data, but the results aren't in terms of frequency and amplitude.
Any guidance on this?
Don't use those ExpressVIs! 😄
When the result of those ExpressVIs don't fit your needs you can always alter them (after opening their frontpanel) or replace them by "basic" LabVIEW code…
do we need to merge the error msg for multiple task?
You talk about the error cluster wires?
You could merge them or you can handle each error "line" on it's own. See what fits your needs!
Message 11 of 11
(1,088 Views)
