Double Click Property Doesn't work on 8.0
I have a program which uses double click property to select an item from a list box (LabVIEW Version 7.1). After upgrading to 8.0, nothing happens when I double clicked. I noticed that the property is not slectable on the property node any more. Does any one tell me why it was removed and how I can get it to work, other than by using Even structure. Thanks
(2,526 Views)
That property has been moved so that it's accessible using the "Invoke" node for the control as "Get Row Double-Clicked".
(2,519 Views)
