Double Diagonal Lines through For Loops
I sometimes get double diagonal lines through my For Loops (Starting from the lower left corner, through to the upper right). My Application still seems to be doing what I want it to, but its a nusance to see them. Is there any reason why they would appear? If so, how do I get rid of them?
(2,677 Views)
Ian,
Do you have the latest video card driver for your machine? If not, please get and install this and see if the issue goes away. If you have the latest driver, then can you post a screen shot of this happening and a small VI that reproduces the issue somewhat regularly? It would also be helpful to post what operating system you are using as well as what version of LabVIEW. Thanks.
Randy Hoskin
http://www.ni.com/ask
(2,677 Views)
