Double digit display of one digit number
Hi all,
I was wondering if there is a quick way of showing one digit numbers between 0-9 as in 00-09.
Best,
Kutal.
(5,301 Views)
Accepted by topic author serkut17
Display Format of your numeric indicator.  Right click and go to properties, choose the Display Format tab.  Choose the Floating Point, with minimum field width of 2, and Pad with zeros on the left.  Then in Data Entry tab choose the range to be from 0 to 9 with coerce if outside that range, and increment of 1.0 if you are using a double.
(5,297 Views)
Thanks a lot for the message, do you have an idea to convert this two digit numbers to string without losing precision
(5,237 Views)
Format into String.
(5,226 Views)
i tried but it eliminated the leftmost integer
(5,224 Views)
Did you set the format string code properly?
Right click on the function and select Edit Format String.
Spoiler
%02d
(5,218 Views)
Just as RavensFan suggested 😛 Check the image below, if still nor clear.
uday
(5,199 Views)
