Double filter in XML
Good morning,
I have an XML, and I need to perform a double filter.
Within BOMList/BOM/MaterialList/TextList, I need to find the InputText1 that contains the text * * * BOARDS * * * and save its ItemNumber
After finding the ItemNumber of * * * BOARDS * * *, I need to retrieve the ItemNumber of the same "family" within BOMList/BOM/MaterialList and save the Component
In this case, the ItemNumber of * * * BOARDS * * * is 1499, so the ItemNumber of the others should be in the range of 1500 to 1600
Can you help me to filter that?
The VI with the xml data it's attached
(887 Views)
What is the criteria for 1500 to 1600? There are no matches for Item Number 1499
CLA, CTA
(826 Views)
