Doubt in DAQ mx
I am virtually using DAQ mx in my application. That is a Analog 1 channel,1 sample .I am plotting that value in a chart. Whan i am running my VI,mx starts  from 4.94. How can i set it to start from zero ? Please someone help me ?
(3,290 Views)
HI CLAD,
you could "manually" subtract the offset.
Maybe there are other reasons for the offset? Differential or single ended measurement? Proper signal grounding?
(3,284 Views)
I am using RSE configuration.Why it shows frome 4.5? Can you please explain ?
(3,280 Views)
What is connected to the DAQ?  Are you reading the right channel (I know, it would be stupid, but I've done it)?
(3,260 Views)
what ????
(3,258 Views)
