Doubt on multiple analog inputs using same DAQ device...
Hi CrackJack,
A quick overview of your code pointed out 2 things:  1) Your digital I/O settings are referencing analog input channels.  As this is not the expected input, these settings are most likely the cause of the error.  2)  A DAQmx Clear Task would probably be a good replacement for the Stop Task as you are never releasing the resources.  This could present problems for you down the road.  Hopefully this helps!
24530i2FACC905590B2FBF
* Please keep one issue per thread
h_baker
Message 11 of 11
(620 Views)
