Downconvert VI Requests
Please use the Version Conversion board to post any requests to upconvert or downconvert your VIs.
In your post, please indicate:
Source LabVIEW version
Target LabVIEW Version
**Once converted, please mark the thread as Solved by selecting "Accept as Solution".
Please remember this is not a space for code discussion. This is just a space for you to post the VIs you need to be converted to an older or newer version of LabVIEW. If an issue arises where you need further assistance after the conversion has been completed (for instance, if you need the converted
VI to be removed from the forums) please select "Report to a Moderator."
Message 1 of 1,444
(41,158 Views)
Can someone help me to convert these Vi´s in an newer version ? They are written in 5.1 and here we have only 8.5.1
So it would be nice if someone can convert it for me.
thx
Message 2 of 1,444
(40,984 Views)
This post is for requesting to save VIs that are in a newer version back to an older version. The Upconvert VI Requests page is for upgrading VIs. In the future, please post there for upgrading older VIs.
Message 3 of 1,444
(40,970 Views)
Could I get the following two 8.6.1 VIs converted to 7.1
Thanks!
Message 4 of 1,444
(40,823 Views)
Hi errante,
not so much luck on downconversion:
One VI (stimbit...) looses a lot of functionality because of unsupported features, the other doesn't even downconvert (WMP..., I got a lot of "insane" errors). The 3rd one is mainly a picture of code Smiley Wink
Message 5 of 1,444
(40,810 Views)
GerdW,
THANKS!
Message 6 of 1,444
(40,796 Views)
In downconverting from labview 8.6 to labview7.1, I ran into ignorance in my coding abilities or a compatibility issue.
In 8.6,  under 'RegEvents' there is a 'Signal' option followed by 'signalType'; however, in 7.1 I am only able to evoke a 'Signal' option.
Is there a solution?
errante
Message 7 of 1,444
(40,760 Views)
That event is from DAQmx, not LabVIEW. So it's an issue with the version of DAQmx. Support for LabVIEW 7.1 goes up to DAQmx 8.9.
Message 8 of 1,444
(40,745 Views)
Can someone be so kind as to convert the UART.zip to a version that i can open with 8.2?
http://decibel.ni.com/content/docs/DOC-1290
Adam
Message 9 of 1,444
(40,688 Views)
Attached is in 8.2, BUT.... The Feedback Node in 8.6 had a global initialization terminal, whereas the one in 8.2 does not. Thus, that node is missing in the VIs. You will need to recode the VIs using the 8.2 Feedback Node. Also, the top-level VI used a Wait Express VI from the RT module. I don't have that, so you'll need to put it in yourself.
Message 10 of 1,444
(40,677 Views)
