Downconvert VI Requests
@DL_LEO wrote:
That didn't work. When I try to load it from Labview 8.5 a prompt says: File version is later than current Labview version.
I am able to open the VIs in 8.6 (I don't have 8.5), and it says the VIs are in version 8.5. Are you seeing this for a specific file? Have you tried opening the subVIs in the Source\SubVIs folder?
Message 1251 of 1,444
(1,492 Views)
Could someone please convert the attached vi from version 8.0 to 7.1? Thanks!
Message 1252 of 1,444
(1,487 Views)
That VI is actually in LabVIEW 2009, not 8.0.
Attached is the VI in 7.1.
Message 1253 of 1,444
(1,476 Views)
Can someone please convert this to v8.5 please. I cant open it!!!
thanks!!!
Message 1254 of 1,444
(1,462 Views)
thanks!!!
Where did you get this example? It's a very poor example. If you are trying to write a VI that uses a template, these templates are already provided with LabVIEW. Just select File -> New... and select the appropriate template.
For whatever it's worth (which isn't much) attached is the VI in 8.5. If I were you, I wouldn't even bother with it.
Message 1255 of 1,444
(1,453 Views)
Ok, I ended up getting Labview 2011 and skip the labview 8.5 conversion.
Now, that files says it has a bunch of missing VI's.
Message 1256 of 1,444
(1,446 Views)
Did you install niScope? If you need further help, please start a new thread, as we are no longer talking about downconverting VIs.
Message 1257 of 1,444
(1,445 Views)
thank you sir!..I will follow your advice.
Message 1258 of 1,444
(1,439 Views)
Hi
I would need VI in 10.0 to be converted to 9.0
Jimi
Message 1259 of 1,444
(1,424 Views)
Hi Jimi,
here it is...
Message 1260 of 1,444
(1,423 Views)
