Downconverting Lvlib
Hi Ben,
no i do not have these specific passwords. I am just talking in general about downconverting lvlibs.
In the original post there was nothing mentioned about passwords.
Andi
Message 11 of 12
(595 Views)
@Ben wrote:
@AndreasKr wrote:
Hi Guys,
this would be the solution for downgrading an lvlib an all of the VIs managed in the lib in one step to an oder LabVIEW version.
Define the source path of the lvlib. Define the path where the older lvlib and its items should be stored. And define the LabVIEW version.
This Creates a copy of the lib in an older version with all its items.
Greetings from austria
Andreas
Replying  7 year old thread?
Did you run that code?
Last I looked you could not back save anything that was password protected.
Ben
Hi Ben,
Sorry for reigniting this 4 YO thread...
If you see the snapshot in the OP's post, the Library Save for Previous method did not have the Version input, which is present in the above snapshot.
So that is the clear difference I get to see, which was what the OP's requirement as well; not the option to back save password protected VIs.
- Partha ( CLD until Oct 2027 🙂 )
Message 12 of 12
(532 Views)
