Downgrade VI from Professional to Base version with DC/RMS element
I have VI containing some elements of Professional version: Basic DC/RMS (to get RMS value of signal)
Is there in Base system analog of this element?
(3,086 Views)
Open this function and remove the hanning window function. The rest of this vi is made by base functions. It may work. If not perhaps you can write your own window function. Should not be to hard. http://en.wikipedia.org/wiki/Window_function#Hann_window. I think hann and hanning is the same. Use google to check it out. Good luck 😉
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,074 Views)
Also see here http://forums.ni.com/ni/board/message?board.id=170&thread.id=371006 No problem at all. But it will be somewhat slower than the orginal labview window function.
Message Edited by t06afre on 01-07-2009 02:12 PM
(3,067 Views)
