Downgrade ni motion
Dear All,
I have a question about NI motion driver. I'm going to upgrade a software whic built using NI motion 8.0, now when i edit the vi for upgrade i'm using NI motion 8.3. Will the upgrade software work on the PC running NI motion 8.0?
Thank you
(5,666 Views)
Good day,
If you are planning to modify the VI with the newer release of the NI-Motion driver then, the PC running ver. 8.0 will have to be upgraded to 8.3.
Here is a compatibility list in case the version of labview that you are currently using doesn’t support NI-Motion 8.3: Which LabVIEW Version Supports NI-Motion?
Alejandro C. | National Instruments
(5,601 Views)
