Download a file programmatically
Hi all,
I'm trying to read data in a file stored on the system of my enterprise. I've a link like this: "http:\ged\management\entites\fupeng\PdT\Organisation\file.txt". I've tried to use this link as path for my reading function, but it doesn't run. I've clearly to first download the file from the link to a local repository. But I don't find how to make...
I'm workin with LabVIEW 2014 SP1.
Thanks per advance!
Francis M
(3,678 Views)
Accepted by topic author Cisco
@Cisco wrote:
Hi all,
Thanks per advance!
Could it be as simple as requiring the source URL to start "http:\\<share>\<path to file>"?  Try adding the second backslash just after the "http:".
Bob Schor
(3,660 Views)
Thank you!
It was just a syntax issue. I've replaced "http:\" by "\\".
Bye!
Francis M
(3,651 Views)
