Download to a file, real-time oscilloscope traces accessed through the web: How?
Our new Textronix oscilloscope was assigned an IP address, and we are viewing this oscilloscope's traces over the web using the IP address assigned. Now, using LabVIEW, we want to download into a file an oscilloscope trace at a particular instant in time, and we want to do it many times as we want. Is LabVIEW 6.1 capable of doing that? If YES, then how? What features do I use?
Thank you very much for your help!
Sincerely,
reynann7
(2,622 Views)
Do a search for the Tektronix model under drivers, you should be able to find a labview driver for the instrument. The Tektronics scope I have (TDS3034) used TekVisa to what looked like "fake" a GPIB bus. When I installed Labview and NI-488 TekVisa would no longer work, I used the serial port on the TDS3034 instead.
Hopfully this points you in the right direction.
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
(2,611 Views)
