Downloaded Instrument Drivers
Please forgive a newbie question. I downloaded several instrument
drivers from the ni site for instruments that I would like to control with
LabView 6i (student version). They run fine when I open the vi's one at a
time and run them.
My question is, How do I tell LabView where they are so that they appear
in the Functions menu under Instrument I/O? There is a sample HP DVM there
already and I would like to see icons pointing to the library functions for
all of my downloaded drivers.
Thanks!
Joe
(2,931 Views)
There is a directory
C:\Program Files\National Instruments\LabVIEW 6.1\user.lib
which specifies what appears on the "user libraries" tab. You might try
linking them from there, or putting them on there, or editing the menu file.
Check the online help for more details.
-joey
"Joe Geller" wrote in message
news:b1g59.123730$D8.4210602@news4.srv.hcvlny.cv.net...
> Hi,
> time and run them.
appear
there
for
> Thanks!
> Joe
(2,930 Views)
The problem was that the student version has a 'LabView 6.1' directory
structure and then a near identical 'LabView SE' structure with another
inst.lib! I got it by searching for the example instrument .mnu file ...
only to find out that my downloaded drivers lived elsewhere. When I moved
my downloaded drivers to the SE inst.lib the new icons popped right up.
(Joey, thank you for pointing me to the menu files!)
-Joe
"Joey Oravec" wrote in message
news:3d55a017@newsgroups....
file.
> Check the on
> -joey
> > Hi,
with
a
> > time and run them.
> appear
> there
> for
> > Thanks!
> > Joe
(2,930 Views)
Joe,
The directory you're referring to is not the user.lib, but the instr.lib. You should put downloaded driver files in the following directory:
:\Program Files\National Instruments\LabVIEW 6.1\instr.lib\
Be sure to create a directory for the driver.
For more details check out the Installation Instructions page.
--Bankim
Bankim Tejani
(2,930 Views)
