Downloading LabView 2009
I need to download LabView 2009 in order to make changes to a vi made using that version.  Does anyone have a link to where I can do so I am having trouble finding it.
Message 1 of 19
(12,723 Views)
I managed to find it here: http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/n8:28,ssnav:pdl/q/LabVIEW%20...
Message 2 of 19
(12,717 Views)
Thanks for the help, but when I go to that link I can see all of the patches but I don't see the base software
Message 3 of 19
(12,704 Views)
His link goes directly to a search that shows two downloads for 2009 SP1 (32bit and 64bit). SP1 just means that it's the base release including SP1. You could alter the search bar to remove "SP1"..., but you really do want the SP1 release.
Cheers
Message 4 of 19
(12,682 Views)
When I click on any of the links in this page I get linked to a page that says there are no results found.Labview site.jpg
Message 5 of 19
(12,664 Views)
Huh...
Try this direct link for 65bit.
or this direct link for 32bit
Cheers
Message 6 of 19
(12,640 Views)
That link comes back with the same page a attached earlier.
Message 7 of 19
(12,627 Views)
Original link works fine for me.
dbaer, do you/ does your employer have a license for LabVIEW 2009?
If they didn't would that explain the link's behavior?  I'm just guessing here.
EDIT: Also the direct links take me to the same page as the original, which still works as James intended.
Message 8 of 19
(12,598 Views)
I was told by our sales rep that I would be able to download it from the online site so I would assume we do.
Message 9 of 19
(12,589 Views)
If you just made this account maybe you haven't associated your company's serial number with it yet?
When you click MyNI near the top right of this page, and then click "My Products" does your serial number show up?
Message 10 of 19
(12,579 Views)
