Downloading compiled FPGA bit file to target
Hello.
I'm trying to use multiple FPGA VIs in a same project, same target.
But, currently the Labview force me to re-compile when I want to run different FPGA VI in same project.
Even after compiling two FPGAs, the Labview program attempts to re-compile when I trying to run differnt FPGA VI.
So I refered http://zone.ni.com/reference/en-XX/help/371599G-01/lvfpgahelp/compiling_fpga_vis_howto/ to download compiled FPGA bit file to the target to transit to another FPGA VI.
However, still the Labview program trying to re-compile the FPGA VI when I click RUN on the VI after downloading compiled VI to the flash of the target.
How can I solve this problem?
P.S.:
I checked off the option of the build specification that the FPGA VI does not automatically run when it is loaded to target and the target switch is on.
(3,035 Views)
Are you sharing VIs between the two top-level VIs?
If they have any conditional disable structures with different settings then the sub-VIs will be marked as changed when opening the top-level VI  for your second target.
Do you need to run the code in interactive mode or can you simply compile a bitfile and use that instead.  That was the compilation requirement disappears.
I agree though that LVs rush to mark VIs as changed is a problem for interactive FPGA mode.
Shane.
(3,007 Views)
