Dr. Damien's Development - Debugging Race Conditions
Here is the 7.0 version.  The lowest version of LabVIEW I have on my machine is 7.1, so I have not tested it.  Let us know if you have problems.
Message 11 of 12
(2,421 Views)
I should have updated this quite awhile ago.  If you are using LabVIEW 8.6 or higher, National Instruments has released a tool to capture LabVIEW events called the Desktop Execution Trace Toolkit.  It can be used to debug code dynamically, since it can capture all sort of events - unhandled errors, event structure events, queues, etc.  It also runs in a separate process, so should not crash if LabVIEW crashes.  It can be used as a complement or replacement for the method above, depending on your needs.  It has the advantage of requiring no code changes.
Message 12 of 12
(2,152 Views)
