Dr. Damien's Development - Improve Load Time with Inlining
@Wiebe: the right-click menu to inline a SubVI is already there, you just have to enable it. Add the following line to the LabVIEW.ini file:
inlineSubVIEnabled=TRUE
Daniel
Message 11 of 18
(5,117 Views)
"dan_u" <x@no.email> wrote in message
news:1229359210538-824142@exchange.ni.com...
> line to the LabVIEW.ini file:inlineSubVIEnabled=TRUE&nbsp;Daniel&nbsp;
Yes, I knew. But this isn't public, is it?
Message 12 of 18
(5,105 Views)
Damien,
I have been using this application with a lot of sucess, and am currently looking into using it in a more automated fashon. I don't know if you are familiar with the microprocessor SDK product, but you generate C code in the same process you would use to build a *.exe.
In order to improve efficiency and minimize memory allocation, I would like to programatically inline my VIs (and save to a different spot) every time I generate C code. I have a really simple VI which does this using your application, but for some reason when I insert my VI (with your VI) inside the plugin VI which generates the C code, I get an error:
Possible reason(s):
LabVIEW:  Invalid Class Operator VI.
Method Name: Class Operator:Set
Do you have any suggestions? Should this work in the context of a plug-in VI? Its hard to diagnose since I do not have access to your VI.
Bill
Message 13 of 18
(4,694 Views)
The TraverseGetObjectReference.vi within Damien's LLB needs to sit right next to the InlineSubVIs.vi in order for the tool to work properly.  So if you are moving VIs around, you need to make sure that these two VIs are still next to each other.
Message 14 of 18
(4,692 Views)
That was it. Thanks for the fast response ... happy ending to a Friday.
Message 15 of 18
(4,687 Views)
I notice that the inliner automatically places a sequence structure around the inlined subVI, is there a way to modify this? I know that if I manually inline the subVI this option is exposed.
Bill
Message 16 of 18
(4,611 Views)
This is exposed in the scripting code, as well, but if you do not have the sequence structure, the execution order of the inlined code may change.  Using it is the safe option.  Since scripting has now been released for "general use", attached is the unlocked code so you can modify as you wish.  It has a fair number of very undocumented nodes, so approach with care.  It is in LabVIEW 9.0.
Message 17 of 18
(4,594 Views)
Thanks.
Message 18 of 18
(4,571 Views)
