Dr Watson errors while using telnet vi's
I seem to randomly get Dr Watson errors while an application is using the standard telnet vi's. I get "c0000005 (access violation)", it works fine after I reboot the machine. It appears randomly about once a week if the program is in constant use. Help. I am using labview 5.0 and NT service pack4.
(2,634 Views)
Not being familiar with your application it's difficult to determine the cause of the problem.
One suggestion would be to delete any lv* files in your C:\windows\temp directory. Then do a scandisk and a disk defrag.
Don't know if this will help. It's possible
there may be a bad block on your harddrive.
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,634 Views)
