Drag & drop using booleans - question !
Hello 2 all !
Here is what i'm trying to do :
I have 2 boolean controls wich are independent one from another on the front panel.
I want to be able to change the state of the "Slave" control by dragging and dropping "Master" over it.
Example :
"Master" - initialy FALSE.
"Slave" - initialy TRUE.
After drag&drop operation:
"Master" - still FALSE.
"Slave" - becomes FALSE.
Here is a vi in wich i've tried to deal with this problem.
Is this behavior possible ?
Thank you !
Andrew.
(3,218 Views)
Accepted by topic author AndreiN2014
do you want to do something similar to this? this is not a perfect example but i hope it will help you
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
(3,204 Views)
Thank you Tushar Jambhekar !
The code that you so kindly provided got me started on the right track :smileyhappy: !
I've modified it a little bit and got to the expected behavior.
Thank you very much !
(3,170 Views)
